A quick question about the ADS1220:
If I only send the RESET command (0x06) to ADS1220, will this reset all the registers of ADS1220 to their default values (all 0s)?
Hi Wen,
Sending the RESET command will reset the ADS1220 registers to the default values. However, communication to the ADS1220 can only take place if both AVDD and DVDD supplies are at a valid voltage supply level.
Bob B
Hi Wen,
If you are using the ADS1220EVM, the RESET command function is not called due to causing synchronization issues with the GUI. Sending the RESET command will function if it is correctly called within a designed application.
Bob B
Hi Wen,
I would probe and just make sure that something simple in the communication isn't going wrong....like CS not going low.
Bob B
