Hi Dear,
I followed the reference design DAC31X1EVM to get a single-ended output by transformer coupling, the schematic is below:
The waveform I want to get likes this:
The problem is the waveform is not expected behind those two transformers:
1) the waveform at DAC3161 side is below, there, green waveform is from a pin P, yellow waveform is from
pin N when I removed the resistor R311,R312. The waveform is right if I make a substruction of Vp-Vn.
2) When I re-populated resisters R311, R312, the waveform likes below:
So, I can not get the waveform I expected by transformer coupling, is it right?
if Yes, could you give some suggestion to get the expected waveform.
Thanks a lot!
Gideon
