Other Parts Discussed in Thread: TMS320F28335
Tool/software: TI-RTOS
Hi
Team
We are trying to use DAC TLV5614 as mentioned
We have using this as external DAC with TMS320F28335 interfaced from SPI
our SPI code works fine and we are able to send data on MOSI lines when probed.
The dac is interfaced with the following voltages as mentioned
DVDD &PD is 1.2V
Ref in AB is 1.2v
Ref in CD 1.2v
AVDD is 5V
and we have made sure the values that we send is proper on MOSI lines and made sure LDAC and CS pin are low
As suggested we are sending the frame format of A0 AI PWR AND SPD
and we are sending data
But there is no Analog output seen and the all channels remains low
Not sure why we are not able to get any ANALOG VOLTAGES ON ANY CHANNEL
Kindly let me know the debugging step or any reference code that is used to drive the DAC
Kindly suggest the solution
Thank you
Deepak R
