Part Number: ADS7947
I'm trying to pin down how to get a single sample out of the ADS7947 when using the channel select. Sample rate is not important (1ksps), but device operation is. From what I can see, you would select the desired channel (via GPIO), and then read out two samples. The first sample would be thrown away (because it was acquired at some point in the distant past), and the second would be the relevant data. I've attached a sample timing diagram below.
Please confirm that my understanding is correct.
Many thanks.
Don
