1) I want to send 16 bit digital data from an FPGA board to DAC5687EVM. The digital values are changing with every rising edge of a100 MHz clock. I want to use the FPGA board as the clock source of the EVM, too. I know it has a poor jitter performance but is it possible to use it?
2) Do I need any software or initial configuration while sending parallel data? (clock and data from FPGA to DAC5687EVM is enough? )
3) I want to monitor the analog voltage output on an oscilloscope but the EVM gives current output 0-20mA. Can I monitor 0-5V analog voltage by just mounting a 250 ohm resistor parallel to the power and ground pins of the SMA?
Thanks a lot for your interest
