Part Number: DAC5687EVM
Other Parts Discussed in Thread: DAC5687
Hi ,
I'm trying to test the dac5687evm. I need 0-1V output. My data is changing with a 100 MHz frequency.
I'm applying 16 bit digital data to J14 and 100MHz clock to J4.
I'm trying to monitor the output from J19 (I'm using a current to voltage converter (an op amp with a 50 ohm feedback resistor) )
The output signal is expected to be a 20 kHz sine wave but I monitored a 60 Hz 1.6Vpp signal (not a sine not a square wave)
How should I configure the DAC5687 EVM ? What I'm doing wrong?
Thanks a lot
