Other Parts Discussed in Thread: LMH6702,
Good Day, I am struggling with knowing what the optimum/proper values of VRT and VRB should be used if I am using the ADC1175 to digitize a video signal (15khz 240x320). A typical video signal on either R,G or B lines is 0v to 0.7v, thus I was going to use the LMH6702 to amplify the signal (as recommended) and then set VRT and VRB accordingly so I have a band of 0.7v to digitize across, however the datasheet says on page 14 that VRT should be 1.0v to 2.8v more positive than VRB thus giving me a wider band than the video signal will have. However the ADC1175 does specify on the cover sheet it may be used for video applications.
Will the ADC1175 operate okay with a 0.7v difference across VRT and VRB?
Or will I still get good video conversion results just setting VRT 1v greater than VRB?
Am I missing something in my understanding?
Thank you!
