Part Number: DAC5681Z
I am using DAC5681Z with dac_clk=200MHz, data_clk=100MHz without interpolation
-->I programmed DAC5681Z with default register values in sequence given in datasheet but didn't get any output,
-->but then I gave only 2 registers (config02 and config0E) ,I got required output
-->then I fed all registers except CONFIG03 and I got the output,
-->If i change the sequence in which i am feeding the registers, output is changing
can you please tell me whether a proper sequence of register sending has to be followed or not
