Part Number: DAC38J84
hi ,all.
And I have some questions to ask.
I am using a chip DAC38J84 in my design, and l configurate the registers of DAC38J84 by Microblaze in KC705 of Xilinx through a AXI Quad SPI IP core. I remember that there is an answer said by Jim :“Setup the DAC to only use the internal NCO and see if you can get an output. Follow the example attached. This will verify the DAC is getting a valid clock, the power is OK and the SPI is working”. I want to know more detail about how to setup the DAC to only use the internal. Should l configurate the regs by following the steps in section 8.3 of the data sheet? By the way, l don’t use the DAC3xJ8x GUI software to configurate the regs, l use the SDK to config. So do you have the example code to setup the NCO testing?
I would be appreciated for your help.
