DAC8760: DAC8760
Part Number: DAC8760
      I am working with DAC8760 when using Voltage output the DAC works fine, but when using current output the Alarm Pin sets low.
     When I read the Status register the result is 0x0008.
     As  per the datasheet this indicates watchdog timer out, but I haven't enabled the watchdog timer so as far as I have programmed I have made sure that the DB2 of the Configuration stays 0.
    Could anyone help me with the problem.
Thank you.
