Hi Shashank,
I split this question off into a new thread since it is a unique issue on it's own. However, if you wouldn't mind following up on your previous thread (ADS1282EVM-PDK: EVM setup with the default MMBO) and letting us know if that issue was resolved, we would really appreciate it!
For this problem, where the PGA negative rail appears to be saturating at a voltage higher than AVSS+0.7V, I need to know the input voltage and the PGA gain that you are using... Mostly likely, the input is exceeding the "Full-scale input voltage", ±VREF/(2 × PGA), which results in a full-scale reading. Might this be what is happening in your setup?
Chris
