Part Number: ADC12DJ2700
Other Parts Discussed in Thread: ADC12DJ3200
Hi to all,
sorry to come back with a similar issue to the mentioned thread.
At the moment we'd like to check, if it is possible to use the Offset-Calibration of the ADC12DJ3200 to remove the external DC-Offsets in addition to the internal ADC-Offsets.
When the offset calibration runs, the input signal is switched off. We only have a unknown and undesired DC-Offset.
Jim wrote on the 23 Feb. 2018:
"If input signals are applied and have certain characteristics (signals at or near DC or aliased signals that will fall near DC) the offset calibration results will be degraded. For this reason we recommend that offset calibration only be enabled when the input signal is known or can be disconnected."
So does this mean, that the external DC-Offset degrade the Offset-Calibration and falsify the measurement performance of the ADC?
Or does this mean, that the ADC-results gets falsified only by the amount of the removed DC-content from the external signal?
If the ADC-results only gets falsified by the amount of the removed DC-content, it wouldn't be a problem for us, because the external DC-Offset is not requested.
Do you know which maximal external DC-Offset is allowed and can be calibrated by the ADC12DJ3200?
Thank you very much for your support.
Best regards
Paul Rott
