Tool/software: Linux
I want to register ads 8688 linux driver from kernel machine file (arch/arm/mach-mx6/board-xxxxx).
I have tried below but do device tree is created under /sys/bus/iio/device nor probe function is called.
static struct spi_board_info imx6_pac_spi_nor_device[] __initdata = {
#if defined(CONFIG_MTD_M25P80)
.modalias = "m25p80",
.max_speed_hz = 20000000, /* max spi clock (SCK) speed in HZ */
.bus_num = 0,
.chip_select = 0,
.platform_data = &imx6_celp__spi_flash_data,
#endif
.modalias = "spidev",
.max_speed_hz = 20000000, //20Mhz
.bus_num = 4,
.chip_select = 0,
.mode = SPI_MODE_0,
.bus_num = 3,
.chip_select = 0,
.mode = SPI_MODE_0,
#if defined(CONFIG_TI_ADS8688)
.modalias = "ads8688",
.max_speed_hz = 100000,
.bus_num = 1,
.chip_select = 0,
.mode = SPI_MODE_1,
#endif
does anyone have sample on how to register the ads8688 on machine file ?
