Part Number: DAC1220EVM
Other Parts Discussed in Thread: DXP
Hi all,
My customer reported that it seems MMB0 does not output the SPI signal to DAC1220EVM.
Could you tell me the procedure to solve it?
EVM settings are as follows;
MMB0 (Rev C):
- DC 6V -> J2
- J12 -> Short
- J13: +5V - +5VA -> Short
+5V - +VA -> Open
DAC1220EVM:
- J13: 1-2 and 3-4 ->Short
- J5: Short
- S1: Internal VREF
- S2: XTAL
OS:
Windows 7 professional SP1, 64bit
DXP Log file:
Wrote to /dxp/drivers/dac/control/configure value TRUE : TRUE Wrote to /dxp/drivers/dac/control/update/source value 0 (0x0000) : TRUE Wrote to /dxp/drivers/dac/control/update/rate value 50 (0x00000032) : TRUE Wrote to /dxp/drivers/dac/control/waveform/offset value 0 (0x00000000) : TRUE Wrote to /dxp/drivers/dac/control/waveform/channels value 1 (0x00000001) : TRUE Wrote to /dxp/drivers/dac/control/configure value TRUE : TRUE Wrote to /dxp/drivers/dac/control/waveform/frequency value 25 (0x00000019) : TRUE Wrote to /dxp/drivers/dac/control/run value TRUE : TRUE Application exited with code 0
=== Logging started: 2018/05/28 14:45:44 === Action start 14:45:44: INSTALL. Action start 14:45:44: SystemFolder.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF. Action ended 14:45:44: SystemFolder.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF. Return value 1. Action start 14:45:44: DIRCA_CheckFX. INFO : [05/28/2018 14:45:44:953] [CheckFX ]: Custom Action is starting... INFO : [05/28/2018 14:45:44:953] [CheckFX ]: CoInitializeEx - COM initialization Apartment Threaded... INFO : [05/28/2018 14:45:44:973] [CheckFX ]: MsiGetPropertyW - Determine size of property 'VSDFrameworkVersion' INFO : [05/28/2018 14:45:44:973] [CheckFX ]: Allocating space... INFO : [05/28/2018 14:45:44:973] [CheckFX ]: MsiGetPropertyW - Getting Property 'VSDFrameworkVersion'... INFO : [05/28/2018 14:45:44:973] [CheckFX ]: Property 'VSDFrameworkVersion' retrieved with value 'v3.5'. INFO : [05/28/2018 14:45:44:973] [CheckFX ]: MsiGetPropertyW - Determine size of property 'VSDFrameworkProfile' INFO : [05/28/2018 14:45:44:973] [CheckFX ]: Allocating space... INFO : [05/28/2018 14:45:44:973] [CheckFX ]: MsiGetPropertyW - Getting Property 'VSDFrameworkProfile'... INFO : [05/28/2018 14:45:44:973] [CheckFX ]: Property 'VSDFrameworkProfile' retrieved with value 'Client'. INFO : [05/28/2018 14:45:44:973] [CheckFX ]: Set VSDNETMSG with the FrameworkVersion. INFO : [05/28/2018 14:45:44:973] [CheckFX ]: MsiGetPropertyW - Determine size of property 'VSDNETMSG' INFO : [05/28/2018 14:45:44:973] [CheckFX ]: Allocating space... INFO : [05/28/2018 14:45:44:973] [CheckFX ]: MsiGetPropertyW - Getting Property 'VSDNETMSG'... INFO : [05/28/2018 14:45:44:973] [CheckFX ]: Property 'VSDNETMSG' retrieved with value 'This setup requires the .NET Framework version [1]. Please install the .NET Framework and run this setup again.'. INFO : [05/28/2018 14:45:44:973] [CheckFX ]: MsiSetPropertyW - Setting Property Value... INFO : [05/28/2018 14:45:44:973] [CheckFX ]: MsiSetPropertyW - Setting property 'VSDNETMSG' to 'This setup requires the .NET Framework version v3.5. Please install the .NET Framework and run this setup again.'. INFO : [05/28/2018 14:45:44:973] [CheckFX ]: MsiGetPropertyW - Determine size of property 'VSDNETURLMSG' INFO : [05/28/2018 14:45:44:973] [CheckFX ]: Allocating space... INFO : [05/28/2018 14:45:44:973] [CheckFX ]: MsiGetPropertyW - Getting Property 'VSDNETURLMSG'... INFO : [05/28/2018 14:45:44:973] [CheckFX ]: Property 'VSDNETURLMSG' retrieved with value 'This setup requires the .NET Framework version [1]. Please install the .NET Framework and run this setup again. The .NET Framework can be obtained from the web. Would you like to do this now?'. INFO : [05/28/2018 14:45:44:973] [CheckFX ]: MsiSetPropertyW - Setting Property Value... INFO : [05/28/2018 14:45:44:973] [CheckFX ]: MsiSetPropertyW - Setting property 'VSDNETURLMSG' to 'This setup requires the .NET Framework version v3.5. Please install the .NET Framework and run this setup again. The .NET Framework can be obtained from the web. Would you like to do this now?'. INFO : [05/28/2018 14:45:44:983] [CheckFX ]: MsiSetPropertyW - Setting Property Value... INFO : [05/28/2018 14:45:44:983] [CheckFX ]: MsiSetPropertyW - Setting property 'VSDFXAvailable' to 'TRUE'. INFO : [05/28/2018 14:45:44:983] [CheckFX ]: Writing config file with version: '2.0.50727'... INFO : [05/28/2018 14:45:44:983] [CheckFX ]: Creating Config File... DEBUG : [05/28/2018 14:45:44:983] [CheckFX ]: Calling MsiGetActiveDatabase... DEBUG : [05/28/2018 14:45:44:983] [CheckFX ]: Calling MsiDatabaseOpenView... DEBUG : [05/28/2018 14:45:44:983] [CheckFX ]: Calling MsiViewExecute... DEBUG : [05/28/2018 14:45:44:983] [CheckFX ]: Calling MsiViewFetch... DEBUG : [05/28/2018 14:45:44:983] [CheckFX ]: Calling MsiRecordDataSize... INFO : [05/28/2018 14:45:44:983] [CheckFX ]: MsiSetPropertyW - Setting Property Value... INFO : [05/28/2018 14:45:44:983] [CheckFX ]: MsiSetPropertyW - Setting property 'VSDFxConfigFile' to 'C:\Users\hwa\AppData\Local\Temp\CFGAD84.tmp'. INFO : [05/28/2018 14:45:44:983] [CheckFX ]: Custom Action succeeded. INFO : [05/28/2018 14:45:44:993] [CheckFX ]: Custom Action completed with return code: '0' Action ended 14:45:44: DIRCA_CheckFX. Return value 1. Action start 14:45:44: AppSearch. Action ended 14:45:44: AppSearch. Return value 1. Action start 14:45:44: FindRelatedProducts. Action ended 14:45:44: FindRelatedProducts. Return value 1. Action start 14:45:44: VSDCA_VsdLaunchConditions. INFO : [05/28/2018 14:45:45:143] [VsdLaunchConditions ]: Custom Action is starting... INFO : [05/28/2018 14:45:45:143] [VsdLaunchConditions ]: CoInitializeEx - COM initialization Apartment Threaded... INFO : [05/28/2018 14:45:45:143] [VsdLaunchConditions ]: Enumerating table using SQL statement: 'SELECT * FROM `_VsdLaunchCondition`' INFO : [05/28/2018 14:45:45:143] [VsdLaunchConditions ]: Calling MsiGetActiveDatabase... INFO : [05/28/2018 14:45:45:143] [VsdLaunchConditions ]: MsiDatabaseOpenViewW - Prepare Database to view table... INFO : [05/28/2018 14:45:45:143] [VsdLaunchConditions ]: TMsiViewExecute - Open Database view on table... INFO : [05/28/2018 14:45:45:143] [VsdLaunchConditions ]: Checking a launch condition... INFO : [05/28/2018 14:45:45:143] [VsdLaunchConditions ]: Getting the condition to evaluate... INFO : [05/28/2018 14:45:45:153] [VsdLaunchConditions ]: MsiRecordGetStringW - Fetching value... INFO : [05/28/2018 14:45:45:153] [VsdLaunchConditions ]: MsiRecordGetStringW - Getting value from column '1'... INFO : [05/28/2018 14:45:45:153] [VsdLaunchConditions ]: Evaluating condition 'VSDFXAvailable'... INFO : [05/28/2018 14:45:45:153] [VsdLaunchConditions ]: RESULT: Condition is true. Nothing more to do. INFO : [05/28/2018 14:45:45:153] [VsdLaunchConditions ]: Custom Action succeeded. INFO : [05/28/2018 14:45:45:153] [VsdLaunchConditions ]: Custom Action completed with return code: '0' Action ended 14:45:45: VSDCA_VsdLaunchConditions. Return value 1. Action start 14:45:45: LaunchConditions. Action ended 14:45:45: LaunchConditions. Return value 1. Action start 14:45:45: CCPSearch. Action ended 14:45:45: CCPSearch. Return value 1. Action start 14:45:45: RMCCPSearch. Action ended 14:45:45: RMCCPSearch. Return value 0. Action start 14:45:45: ValidateProductID. Action ended 14:45:45: ValidateProductID. Return value 1. Action start 14:45:45: WindowsFolder.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF. Action ended 14:45:45: WindowsFolder.30729.6161.Microsoft_VC90_CRT_x86.QFE.C8AE193F_7C6D_330A_93C7_EBBC23C30DBF. Return value 1. Action start 14:45:45: WindowsFolder.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4. Action ended 14:45:45: WindowsFolder.30729.6161.policy_9_0_Microsoft_VC90_CRT_x86.QFE.ED5CDF42_FC23_3F0F_80FC_C138299ADCC4. Return value 1. Action start 14:45:45: CostInitialize. Action ended 14:45:45: CostInitialize. Return value 1. Action start 14:45:45: FileCost. Action ended 14:45:45: FileCost. Return value 1. Action start 14:45:45: IsolateComponents. Action ended 14:45:45: IsolateComponents. Return value 1. Action start 14:45:45: CostFinalize. Action ended 14:45:45: CostFinalize. Return value 1. Action start 14:45:45: SetODBCFolders. Action ended 14:45:45: SetODBCFolders. Return value 1. Action start 14:45:45: InstallValidate. Action ended 14:45:45: InstallValidate. Return value 1. Action start 14:45:45: InstallInitialize. Action ended 14:45:47: InstallInitialize. Return value 1. Action start 14:45:47: AllocateRegistrySpace. Action ended 14:45:47: AllocateRegistrySpace. Return value 1. Action start 14:45:47: ProcessComponents. Action ended 14:45:47: ProcessComponents. Return value 1. Action start 14:45:47: MsiUnpublishAssemblies. Action ended 14:45:47: MsiUnpublishAssemblies. Return value 1. Action start 14:45:47: UnpublishComponents. Action ended 14:45:47: UnpublishComponents. Return value 1. Action start 14:45:47: UnpublishFeatures. Action ended 14:45:47: UnpublishFeatures. Return value 1. Action start 14:45:47: StopServices. Action ended 14:45:47: StopServices. Return value 1. Action start 14:45:47: DeleteServices. Action ended 14:45:47: DeleteServices. Return value 1. Action start 14:45:47: UnregisterComPlus. Action ended 14:45:47: UnregisterComPlus. Return value 1. Action start 14:45:47: SelfUnregModules. Action ended 14:45:47: SelfUnregModules. Return value 1. Action start 14:45:47: UnregisterTypeLibraries. Action ended 14:45:47: UnregisterTypeLibraries. Return value 1. Action start 14:45:47: RemoveODBC. Action ended 14:45:47: RemoveODBC. Return value 1. Action start 14:45:47: UnregisterFonts. Action ended 14:45:47: UnregisterFonts. Return value 1. Action start 14:45:47: RemoveRegistryValues. Action ended 14:45:47: RemoveRegistryValues. Return value 1. Action start 14:45:47: UnregisterClassInfo. Action ended 14:45:47: UnregisterClassInfo. Return value 1. Action start 14:45:47: UnregisterExtensionInfo. Action ended 14:45:47: UnregisterExtensionInfo. Return value 1. Action start 14:45:47: UnregisterProgIdInfo. Action ended 14:45:47: UnregisterProgIdInfo. Return value 1. Action start 14:45:47: UnregisterMIMEInfo. Action ended 14:45:47: UnregisterMIMEInfo. Return value 1. Action start 14:45:47: RemoveIniValues. Action ended 14:45:47: RemoveIniValues. Return value 1. Action start 14:45:47: RemoveShortcuts. Action ended 14:45:47: RemoveShortcuts. Return value 1. Action start 14:45:47: RemoveEnvironmentStrings. Action ended 14:45:47: RemoveEnvironmentStrings. Return value 1. Action start 14:45:47: RemoveDuplicateFiles. Action ended 14:45:47: RemoveDuplicateFiles. Return value 1. Action start 14:45:47: RemoveFiles. Action ended 14:45:47: RemoveFiles. Return value 1. Action start 14:45:47: RemoveFolders. Action ended 14:45:47: RemoveFolders. Return value 1. Action start 14:45:47: CreateFolders. Action ended 14:45:47: CreateFolders. Return value 1. Action start 14:45:47: MoveFiles. Action ended 14:45:47: MoveFiles. Return value 1. Action start 14:45:47: InstallFiles. Action ended 14:45:48: InstallFiles. Return value 1. Action start 14:45:48: PatchFiles. Action ended 14:45:48: PatchFiles. Return value 1. Action start 14:45:48: DuplicateFiles. Action ended 14:45:48: DuplicateFiles. Return value 1. Action start 14:45:48: BindImage. Action ended 14:45:48: BindImage. Return value 1. Action start 14:45:48: CreateShortcuts. Action ended 14:45:48: CreateShortcuts. Return value 1. Action start 14:45:48: RegisterClassInfo. Action ended 14:45:48: RegisterClassInfo. Return value 1. Action start 14:45:48: RegisterExtensionInfo. Action ended 14:45:48: RegisterExtensionInfo. Return value 1. Action start 14:45:48: RegisterProgIdInfo. Action ended 14:45:48: RegisterProgIdInfo. Return value 1. Action start 14:45:48: RegisterMIMEInfo. Action ended 14:45:48: RegisterMIMEInfo. Return value 1. Action start 14:45:48: WriteRegistryValues. Action ended 14:45:48: WriteRegistryValues. Return value 1. Action start 14:45:48: WriteIniValues. Action ended 14:45:48: WriteIniValues. Return value 1. Action start 14:45:48: WriteEnvironmentStrings. Action ended 14:45:48: WriteEnvironmentStrings. Return value 1. Action start 14:45:48: RegisterFonts. Action ended 14:45:48: RegisterFonts. Return value 1. Action start 14:45:48: InstallODBC. Action ended 14:45:48: InstallODBC. Return value 0. Action start 14:45:48: RegisterTypeLibraries. Action ended 14:45:48: RegisterTypeLibraries. Return value 1. Action start 14:45:48: SelfRegModules. Action ended 14:45:48: SelfRegModules. Return value 1. Action start 14:45:48: RegisterComPlus. Action ended 14:45:48: RegisterComPlus. Return value 1. Action start 14:45:48: InstallServices. Action ended 14:45:48: InstallServices. Return value 1. Action start 14:45:48: StartServices. Action ended 14:45:48: StartServices. Return value 1. Action start 14:45:48: RegisterUser. Action ended 14:45:48: RegisterUser. Return value 1. Action start 14:45:48: RegisterProduct. Action ended 14:45:48: RegisterProduct. Return value 1. Action start 14:45:48: PublishComponents. Action ended 14:45:48: PublishComponents. Return value 1. Action start 14:45:48: MsiPublishAssemblies. Action ended 14:45:48: MsiPublishAssemblies. Return value 1. Action start 14:45:48: PublishFeatures. Action ended 14:45:48: PublishFeatures. Return value 1. Action start 14:45:48: PublishProduct. Action ended 14:45:48: PublishProduct. Return value 1. Action start 14:45:48: InstallExecute. Action ended 14:45:48: InstallExecute. Return value 1. Action start 14:45:48: RemoveExistingProducts. Action ended 14:45:48: RemoveExistingProducts. Return value 1. Action start 14:45:48: InstallFinalize. Action ended 14:45:48: InstallFinalize. Return value 1. Action ended 14:45:48: INSTALL. Return value 1. MSI (s) (24:44) [14:45:48:963]: Product: TiDacEvm -- Installation completed successfully. MSI (s) (24:44) [14:45:48:963]: Windows インストーラーにより製品がインストールされました。製品名: TiDacEvm、製品バージョン: 1.0.11、製品の言語: 1033、製造元: 、インストールの成功またはエラーの状態: 0 === Logging stopped: 2018/05/28 14:45:48 ===
Toshi
