Dear all,
I see from the datasheet that I can use the +-5V for the MPC506 power supply,but how it changes its electrical caracteristics?
ciao
David
Dear all,
ciao
David
David,
The primary difference is the Ron of the switch. See the normalized curve at the top right side of page 8 of the datasheet. Basically it increases as you lower the supply voltages.
Bob B
Dear Bob,
Thanks for your fast answer, what the ROn is?And its increase what it means?
ciao
David
David,
Ron is the resistance of the analog switch when the switch is 'on'. It becomes very significant when you have low impedance connected on either side of the switch, as a voltage will be dropped across the switch resistance. The maximum resistance is 1.5K ohms for +/-15V supply and would be maximum of (1.3) *1.5K ohms or 1.95k ohms for +/-5V supply.
Bob B
