Part Number: ADS1261
Other Parts Discussed in Thread: ADS1260,
Hallo,
I have to measure two signals alternating on 2 Inputs of the ADS1260/61. What is the effect of the digital filter, when I toggle the inputs after every conversion?
Michael Kathan
Hi Michael,
Welcome to the TI E2E Forums!
The SINCn filter behaves much like a moving average filter, collecting "n" conversion results and averaging them together... Therefore, depending on which filter type you select, switching channels will require the filter to first collect "n" samples before providing a valid output. Therefore, you'll notice that the SINC2, 3, and 4 filters require about 2, 3, or 4 conversion periods until you get the first conversion result.
Refer to section 9.4.1.3 (Conversion Latency) in the ADS1261 datasheet. If you plan on collecting a single samples from channel 1 and switching to channel 2 (etc...) then the fastest data rate you'll be able to achieve will be given by "1 / t(STDR)".
NOTE:
Also, there is an Excel Calculator for the ADS1261 that you might find of interest, found here:
Chris
