Other Parts Discussed in Thread: PGA900, ADS124S08
Hello TI experts
I want to use the LMP90100 in 2 different sensors at the same time but i will not be using the RTD and the load sells as components but instead i will be using for the bridge 3 fixed resistances and one that i will be changing manually as for the RTD i will be using a resistance that i will be changing as well. My goal is that i want to create a precision multimeter and for a start i want to mesure different resistances with 2 diffrent methodes to validate the results.
I tried doing that with the PGA900 but i had a problem withreading the ADC registers, and my question is is it possibol to do theise two different montages on the same LMP90100 and if so is there any recommandations or any side devices that i should use. if not, what AFE would you recommand to do the desired work
regards !
