Hi support team,
I have a question regarding PCB layout of ADS7945. It is recommended in the datasheet of ADS7945 that a spilt ground plane for analog and digital enables better results.
And the ADS7945 ground pins are connected to a common ground plane through multiple vias, which are formed by shorting analog ground and digital ground together. Since there are many ADCs used in the overall design,
a common ground plane for each ADC seems to contradict the principle of single-point grounding in PCB layout. Hence, how do multiple common ground planes return back to power supply without any
possible crosstalk between analog ground and digital ground? What is the usual practice of PCB layout for GND pin of ADS7945? What is the relationship between common ground plane and negative point of power supply?
Sincerely,
H.C
