I have a question about how electrode impedance should be calculated using the AC current sources configured by the LOFF register.
(1) When using the 6nA at 31.2 Hz AC current configuration, is this signal expected to be centered at zero with peaks and troughs at +3nA and -3nA, respectively? Or, is the signal centered at +3nA, with peaks and troughs at +6nA and 0nA, respectively?
(2) When calculating the impedance values, should I divide the output voltage by 6nA or 3nA? When I divide the output voltage (Vrms) by 6nA, I consistently get impedance values that are on half what is expected.
Thank you in advance for the clarification!
