If AFE5818 support differential signal input ? If not , if there any reference design or advice ? many thanks ~
Hi Andrew,
AFE5818 requires the analog input to be single ended.
You may use transformer or amplifiers to convert the differential signal to single ended.
We do not have any reference design for this block.
For transformer, you can check Coilcraft device WBC1-1.
The amplifier should have low noise 1nV / rtHz and with at least 200 MHz unity gain BW.
