Part Number: DAC8760
Other Parts Discussed in Thread: XTR111, DAC8775
Dear all,
I'm wondering if there is a practical and safe solution to multiplex the DAC8760 analog output on three different outputs.
Basically I'm designing a 3-axis tilt sensor with analog outputs (0-5V, 0-10V, 0.5V-4.5V & 4-20mA) but I cannot use 3 different DAC8760 because the PCB space is an issue and it must be reduced.
I've noted this application node but I'm wondering if someone of you have already solve the issue with an alternative and simple solution.
Thinking on how to multiplex the standard output voltage ((0-5V, 0-10V, 0.5V-4.5V), a capacitor must filter the multiplexed management, but what for the output current.
An enough big series inductor can do the same job?
Thanks in advance to anyone can help me.
