Other Parts Discussed in Thread: ADS1292, ADS1298
I down loaded the software and seems the loaded properly but when I plug the eval kit to USB the computer does not recognize the board on the USB. How do I get around this? Thanks
Hi Alex,
Thanks for the note and I tried the eval kit with the windows 7 and still didn't work and show the same symptoms as the windows 10. Seems like the window does not see the kit on the USB and I didn't see any notes as in the application in regard to configuration of the USB port. I can configure the USB port for different setting such at baud rate and so on if I know what they are for this kit. If you can send some information on USB setting I will try it. Thanks again.
Hi Nasser,
I do not have the manual configuration settings that would be required, nor am I sure that it would work.
Have you tried additional USB wires to ensure that the wire is fine?
Can you take a screenshot of your device manager and show where the USB driver is pointing to, like below?
You may need to uninstall the current driver and re-install using the file explorer that points to the correct folder.
I recommend completely uninstalling and re-installing the software as administrator.
