Part Number: DAC60501
According to the Datasheet of the DAC60501 P18 (attached image), Table 1 shows the Address (A) byte as having 9bits (DB[32:24]), while Figure 9. shows the SCL and SDA timing requirements for the Address byte is 8bit, followed by the Aknowledge bit. All the other bytes (Command, MSDB, LSDB) are 8bit.
Table 1 should show Address (A) byte as having 8bits (DB[31:24]), correct?
