Part Number: ADS1256
I am using an ads2256 converter. I have successfully interfaced with my controller, enabled relevant settings and all. However, when the input buffer is enabled, the adc readings go outside of the fsd set through the pga. When exactly is the best time in the conversion process to enable/disable the input buffer?
At the moment I switch the buffer on or off before changing the mux bits. I previously tried enabling/disabling the buffer after mux selection before pga confoguration, but the results are the same. I read mostly negative values on single-ended inputs.
The usage of the adc involves setting channel-specific configurations in the pga and buffer subsystems.
Kindly enlighten.
