Part Number: TLV5614
Other Parts Discussed in Thread: DAC60504
Hello team,
We are using TLV5614 DAC in one of our design, when I power on and power off the power supply repeatedly, and I found some TLV5614 have issues as below:
1. The VOUTA~D of TLV5614 output random voltage value when power on, the MCU doesn’t control the TLV5614 when power on. But the output voltage are 0~4.8V, which isn’t ~0V.
2. How does the TLV5614 power-on reset? Why the registers don’t be cleared when power-on.What conditions are required to power-on reset?
3. Is there any timing sequence requirement for the power supply and the reference voltage?
In my design, the AVDD and DVDD connect together to 5V, and the REF2.5V is powered by 5V, the rise time of 5V and REF2.5V are ~2ms.
4. In my design the control signals have 10k pull-up resistor to 3.3V, the 3.3V is powered by 5V,the rise time of 3.3V is ~2ms.
Is there any timing sequence requirement for the power supply 5V and control signal power supply 3.3V?
Attached is the circuit diagram. Please help to review, and give recommends and solutions.
Look forward to your support, as the project is urgent, please reply ASAP. Thank you.
Kevin
