Other Parts Discussed in Thread: DAC5687
Hi
We are using DUC GC5016---> CFR GC1115---->DAC5687 in our transmit chain.
The CFR input is complex, one channel parallel IQ and output is one channel ,complex with OUT_A = I sample from channel A and OUT_B= Q sample from channel A.
The DAC is connected such that CFR's OUT_A is routed to DAC A port and OUT_B is routed to DAC B port with register interl = 0.
We are taking DAC Output from IOUTA1/IOUTA2 only, we are not using the IOUTB1/B2
My question is since our CFR output is parallel IQ going separately to the DACA and DACB ports, how does output appear only at IOUTA1/IOUTA2 port. I believe the DACA and DACB chains are independent and would process only the data available on their indiviual ports. By this logic input I data should be processed by DACA chain and appear only at IOUTA1/A2 whereas Q data processed by DACB chain appearing only at IOUTB1/B2 but then how do we get the output at only IOUTA1/IOUTA2 port?
