Part Number: DAC81416
With this evaluation module (DAC81416EVM), what is the max power dissipation?
I don't find this information in the user guide of the DAC81416EVM.
Laurent Lefevre.
Laurent Lefevre.
Laurent,
In general EVMs are not specified with power dissipation figures, those kind of numbers would be found in a datasheet. Furthermore, power dissipation will also depending on loading conditions.
I would suggest you take a look at the DAC81416 device datasheet and see if that helps you assess your power concerns, if you are not able to find any information then I am happy to help if you can give us some more guidance on your use conditions with the part.
