Part Number: LM98620
Can we test ADC working using test pattern & which pin we need to monitor the verify pattern outputs (TESTO_1 or TESTO_0 or any other pin)
Hi Sheree,
Let me contact the expert for this part. You can expect a response by 11/4/19.
Grant
Hi Sheree,
The test patterns are internally generated, the pattern enable and format are set in reg38-3F.
You can use these pattern for system digital and timing calibration. Instead of having an unknown analog input, a known pattern is used
for system data processing verification.Data pattern output are the LVDS pins.
Costin
will ADC get heat while operation
what will be the max heat at body surface Vs time
It is recommended to have heat sink for safety operation
Hi Sheree,
Please refer to your new post for the answer to your question.
https://e2e.ti.com/support/data-converters/f/73/p/854582/3161176
Grant
