AMC1204: How to read the AMC1204 output signal
Part Number: AMC1204
Other Parts Discussed in Thread: AMC1210
Hi Expert,
The customer is surveying the AMC1204 into the AC charging station applicant.
And they will use the MCU,STM32F407 to read it.
Pls advice how to read the AMC1204 output signal?
Thanks.
Eric Lai
Field Application Engineer
Texas Instruments Taiwan Limited
O: +886-2-2175-2582
M: +886-909-262-582
E-Mail:Eric.Lai@ti.com
  • Hi Eric,
    I am not familiar with the capabilities of the processor you are using with the AMC1204.  The output of this modulator is a serial bitstream, you need to use a digital filter (sinc3 for example) to capture the bit stream and process the data contained in it.  If the processor does not have a proper means to filter the bitstream, you can use a device like the AMC1210 to accommodate this function.
