Condition: Using the connection in the data sheet 8.5.2 of DAC088S085.
2. If I want to control the same DAC continuously, how should I control it ?
Thanks for writing to us.
In a basic Daisy chain configuration, no of clk cycles required will be depends on no of devices in chain. In the example case we have 3 devices, so we need 48CLK cycles if you want to send data into all DAC's.
You need to send 48CLK and data into the first device which will then clocked out into other devices in the chain as long as you keep SYNC signal low for 48SCLK.
1. You need to send dummy data for DAC1 and DAC3 in the chain and actual data for DAC2
2. I have never tried this, sending only 32SCLK and in theory it should work, but you need to shuffle data accordingly
As I said, please verify this configuration.
AK
