Other Parts Discussed in Thread: DAC5682Z, DAC5687-EP, DAC5688, DAC5687
Hi Team,
I want to know Noise Spectral Density figures of DAC5687-EP and DAC5682Z.
I have to decide the concerned IC asap to freeze my design
Beat Regards,
Tom Liu
Hi Tom,
We don't have the requested data. We will have make a measurement and get back to you with the results early next week.
Neeraj
Hi Tom,
For the NSD of the DAC5687-EP you can use the NSD specs in the DAC5688 datasheet. These two devices are very similar and will have similar NSD specs.
As for the DAC5682Z, we are currently working on taking measurements for the NSD and will get back to you with the results.
David
Hi Tom,
I have tested the DAC5682Z and found that its has a NSD of -161 dBm/Hz, which is the same value that the DAC5687 has from the datasheet.
David
