Part Number: ADS4149
I have the ADS4149 ADC in the RX of our TR modules (as this system is a big phased array) and due to some issues we have a couple of queries.
First and more important, we are measuring the Noise Figure (NF) of our RXs and we obtain differences up to 0.7dB (our RX has around 40dB analog gain). We ensure lots of things like the analog noise floor is around 10dB over the digital noise floor, we have a good adaptation in the ADC at frequencies we work (around 700MHz as we’re oversampling) and all this short of things. We suspect the way this part is mounted could be the problem as removing the ADC and mounting this one or a new one the NF sometimes is enhanced or sometimes is got worse (with a difference in the performance up to 0.7dB, I mean in NF of the whole RX, as we mentioned). Have you ever seen something similar? Or have you ever heard this from your clients? Maybe this difference in the performance of the ADC is not so weird, but I would like to know your impressions.
Second, we were using offset correction configuring digital functions of the ADC and we realized something curious. We reduce NF more than the Friss Equation permits and consequently we were investigating and finally we saw the gain of the ADC change with the signal level ADC receives. Just to clarafy, of course we freeze to stop estimating that correction in periods we are comparing gains. We have red datasheet and we don’t seen a detailed explanation of this correction process. Could you give us more details of this process? Do you have an idea how is this possible?
