Part Number: ADS7830
Could you help to check few questions as below?
1. what is the data update rate?
2. will the data be stored in register? Or ADC will keep updating data and user needs to keep polling the data everytime?
Thank you.
Thank you.
This device does not have a buffer to store conversion output data.
Please refer to the timing diagram below. The voltage input at the time of Command Byte will be sampled. This value is then converted and outputted at the next read byte. A new sample will not be acquired until a new command byte is sent.
Cynthia
