Part Number: ADS122C04EVM
Other Parts Discussed in Thread: ADS122C04
please help me. how i convert 3-wire rtd data analysis reading to temperature value?
i measured 4 cases and connected the evm according yours recommendation:
case 1: i connected 100 ohm external resistor to the evm to pins 2,3 and 5 and got 715753 decimal reading result. according pt-100 datasheet 100ohm is 0 deg.
case 2: i connected 165.5 ohm external resistor to the evm to pins 2,3 and 5 and got 1180610 decimal reading result. according pt-100 datasheet 165.5ohm is 172 deg.
case 3: i connected 151.1 ohm external resistor to the evm to pins 2,3 and 5 and got 1078692 decimal reading result. according pt-100 datasheet 151.1ohm is 134 deg.
case 4: i connected 90 ohm external resistor to the evm to pins 2,3 and 5 and got 644701 decimal reading result. according pt-100 datasheet 90ohm is -25 deg.
how i can ensure that its a right result ? or not? and how to convert it to temperature value?
thank you,
Nikolay Philip
