TLA2518: SPI correctly work when I touch the DVDD
Part Number: TLA2518
I am using this chip as ADC. As mentioned in the datasheet, I have connected two 1uf on both DVDD and AVDD. I use 3.3V. But I get correct reply when I touch the DVDD, can someone please tell me how to avoid that issue.
Thank you,
Yawi
  • Hi Yawi,
    You are not really giving enough information to go by here.  What is your interpretation of 'correct reply'?  How about taking a look at the solder joints on your board as a starting point?  The TLA2518 datasheet does not specifically say this, but touching DVdd is not required for proper operation of the chip!
