Hi team,
Customer is using our DAC8163T and when power on, vout will at mid-scale 2.5V.
They're using internal vref and after reset(CLR pin goes low and then high), Vout will go to 0V and stuck at 0V.
Do you know what might be the reason why Vout could not stay at 2.5V after reset?
I found a description in datasheet : No device pin should be brought high before applying power to the device.
We could not guarantee there's no clock signal before device power on.
Is it still okay in this case?
They had used DAC8163T for years and this is the first time they see this issue.
Thank you.
Cindy
