Other Parts Discussed in Thread: ADS7280
I am interfaceing to the ADS7280 with an FPGA. I had generated the CONVST signal looking like the timing diagrams in the data sheet insuranting the low time is greater than 50nS. It was suggested tome that I should make the low time the whol conversion cycle and then just bring it high and then low right before the conversion which makes the CONVST signal look like the inverse of how you show it. Is there a problem with doing it like this, any advanage or disadvantage to either way?
Also We are debating on the advantage and disadvantage to using tghe SCLK to drive the conversion. If I use the internal Conversion the actualy sample is held on the falling edge of the CONVST so the value is syncronized to the CONVST signal no matter what clock is used as the conversion clock right?
And
P33 of th spec mentions the quite zone. Does this apply to all signals or only the CS? Is it better to leave the SCLK off during the quiet zone?
thanks
John
