Part Number: ADS1298R
Other Parts Discussed in Thread: ADS1298
Hi all,
we have been working for some time with the ADS1298, we were having some trouble with our custom board and so we tested the evaluation model and something in the results are not clear:
1. we are not using the RLD, not sure if this would affect anything.
2. we tested the Voltage values on some resistors using 24nA, and found out that the zero ohm resistor would give about 360uv, which means all the other results we would have to substract this value to get actual voltage response, the issue is that this internal resistance would change from channel to channels and from board to board which means we would need a calibration for each board.
is the RLD required to be able to receive correct results without the 360uv offset ?
thanks in advance,
Jameel
