ADS42LB69: Clock phase noise jitter
Part Number: ADS42LB69
Other Parts Discussed in Thread: LMK04828
For the ADS42LB69 ADC, can TI provide phase noise performance of the clocks used to obtain datasheet specifications?  While using jitter as a means of clock specifications is common to do, if comparing clock generation chips among vendors (and they do not use the exact same method) then it's a bit more complicated to sort out.  If I have a phase noise plot then I can easily compare clock1 to clock2.
