Part Number: DLP3010LC
How to create a 1D pattern? Which software could generate this?
Hello User,
Welcome to the E2E forums and thanks for your interest in our DLP technology.
Can you be more specific on what you are trying to do. If your interest is in generating 1D patterns for use with our Light Control EVMs, I believe you are looking at the correct tool (the DLP Display and Light Control GUI).
For more information on this tool you can consult the user's guide: https://www.ti.com/lit/ug/dlpu074a/dlpu074a.pdf
You can also check out the DLP Pico FAQ page for more guidance on using the GUI with the DLP2010-LC, DLP3010-LC and DLP4710-LC EVMs: https://e2e.ti.com/support/dlp-products-group/dlp/f/dlp-products-forum/729968/faq-light-control-evms-dlp4710evm-lc-dlp3010evm-lc-and-dlp2010evm-lc
I hope this helps.
Philippe
HF NG,
To generate 1D pattern image you should use DLP Display and Light Control GUI as documented below:
Are you having difficulties with the above software?
Philippe
Hi you can create a 1D .bmp image in a couple ways.
1) you can use a tool such as MS Paint to create a black/white monochrome image and save as a .BMP
2) you can take an image that is the desired pattern and pass it through an online .bmp converter. I found that https://online-converting.com/image/convert2bmp/ Works well for 1D patterns
Arthur Brown
