Part Number: DLPDLCR3310EVM
Can someone tell me the following;
a) I want to know the contrast ratio of DLPDLCR3310EVM for full on, full off and checkerboard pattern.
b) Also where can I find the contrast ratio of all the DLP series EVM having optical module, controller and power section integrated in them.
Thank you,
Vedashree.
Hello Vedashree,
I am checking about this with my team. Will get back to you by early next week.
Mayank
Hello Vedashree,
Thank you for your patience on this response.
We expect the Full on/off contrast to be in the range of 400:1, although we cannot specify the contrast value. With a custom built engine, much higher contrast can be achieved by designing the optics to a slower F#. This typically will have an inverse relationship to the brightness. Higher brightness with a laser based optical design typically will achieve 2500:1 by using slower F#s, such as f#3.
We typically do not measure ANSI Checkerboard contrast on our Pico projectors as the size and cost of the projection lens impacts the results. Values will vary significantly.
Kind regards,
Austin
