Other Parts Discussed in Thread: DLPC410
Hello
1. Does the DLPC910 has power up and power down requirements?
2. How does the DLPC910 power up is in relation to the DLPR910. who should ramp up first?
Thank you!
Hello again Moshe,
Good to hear from you.
The data sheet has very little regarding any power up sequencing. There is a DLPC910 reference design that uses the output of some regulators to enable some of the other regulators. As a starting point I would follow that design. https://www.ti.com/tool/TIDA-00570
The DLPC910 differs from the DLPC410 in this regard. On the DLPC910, the FPGA runs the configuration clock, so that the PROM will wait until the FPGA starts the clock. I do not know the entire handshake process, but if the PROM comes up first it will wait.
I hope this helps
Fizix
Hi fizix,
Very nice of you for the prompt and detailed reply as always.
- regarding 1. i will look into the refernce design. i nparallel i checked with Xilinx and no power up sequence is needed.
- regarding 2. makes sense to ramp the DLPR910 first and let it wait. again, verified with Xilinx and this is the recommended wat to do.
cheers.
ML
