Part Number: DLPLCRDC4422EVM
Hello TI,
we would like to use the batch file function of DLPC4422 GUI, however can't find the file format spec. An example file would probably do as well.
Matthias
Hello TI,
Matthias
Hello Matthias,
Hopefully I can offer some clarification, I initially had some confusion as well.
The DLPC4422 GUI has the ability to create and run batch files. Under 'View' make sure 'Projector Control' is selected. In the top bar there is available a 'Record batch file', this will create a batch file and you can change the configuration to your liking. After finishing your desired configuration you need to press the 'Stop recording' button afterward.
Feel free to check this file for the structure as well. I've attached a 'NewBatchFile.bf' with an example which utilizes horizontal and vertical flip in the 'DMD' section.
Aaron B
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/94/NewBatchFile.bf
