Part Number: DLP3021-Q1
Other Parts Discussed in Thread: TMP451-Q1, TMP411-Q1, TMP411, TMP451
Hi team,
The temperature measurement IC recommended by DLP3021 uses TMP411-Q1, but due to insufficient PCB area, I want to use TMP451-Q1 instead. Is it possible to directly replace it? If FPGA does not support TMP451-Q1, it can be detected by MCU. But can you provide the relevant parameters (η-factor and β) of the built-in sensing diode of DLP3021-Q1? Or it is recommended to directly use the preset values of TMP451-Q1.
For the same purpose, can the JTAG-related IO wiring of FPGA to DMD be omitted?
thanks
