DLPC7540EVM: Out of box failure of evaluation board.
Part Number: DLPC7540EVM
Other Parts Discussed in Thread: DLP650TEEVM, , DLP650NE, DLP651NE, DLPC7540
I have a brand new DLPC7540EVM, and DLP650TEEVM and it never worked properly out of the box.  Am I correct in assuming that the dev board will switch to the HDMI input automatically if present?
Attached is my setup and the things I have tried.
Can I get a replacement?
Paul
DLP650 Evaluation Board Test Setup.pdf
Debug opened on URT0
I2C Port 1 initialized as Master port
I2C Port 2 initialized as Master port
I2C Port 0 initialized as Slave port
eeprom: Content validated
Cal data block CWLamp not in EEPROM : Using data from flash
Cal data block SSI present in EEPROM. Data version = 0
Cal data block ADC not in EEPROM : Using data from flash
Cal data block WpcSensor present in EEPROM. Data version = 4
Cal data block WpcBrightness present in EEPROM. Data version = 4
Cal data block XPR present in EEPROM. Data version = 4
Cal data block XPRWaveform not in EEPROM : Using data from flash
Cal data block EdgeBlend not in EEPROM : Using data from flash
Cal data block SurfaceCorrection won't fit in EEPROM : Using data from flash
Cal data block SurfaceCorrection not in EEPROM : Using data from flash
Cal data block BlendMap won't fit in EEPROM : Using data from flash
Cal data block BlendMap not in EEPROM : Using data from flash
API version: 4.5.0.0.0.0
App version: 4.5.0.0.0.0
sysmon: URT Cmd Handlerfailed to start
pca9539: Error - iox failure. APIcc = -7
IT6807 - Configuring IT680x...
digcontrol: Cfg complete
digcontrol: Decoder 2 powerStandby complete
digcontrol: Decoder 5 powerStandby complete
datapath: PowerStandby Complete..
sysmon: DLPA100 not present
illumination: Starting SSI Initialization...
  Configured SSI Driver Type = 0.
  Configuring sensor failed : -6.
  Initializing WPC configuration...
  SSI initialization failed.
Sysmon: Transition to normal operating mode
  Initializing WPC Failed: -6
  Initializing WPC calibration data Passed...
  Initializing WPC Brightness Table Failed: 0
datapath: autolock initialization passed
digcontrol.c : line - 194 : digcontrol_powerNormal()
iox_edid_init() failed
digcontrol: powerNormal failed
digcontrol: powerNormal complete
datapath: dig, adc, dec powerNormal
source: SetUserSFGColor = 1
9
dispfmt_CalculateDisplayArea:  X, Y, Width, Height = 0, 0, 3840, 2160
dispfmt:apply_disp: activeSource = 1, dispSrc = 1
source: SPLASH address:  0x104a84c0
source: DisplaySplash size = 3840 x 2160
Blank screen is set to splash
dispfmt: minPan, pan, maxPan:0, 0, 0
         data = { 3840, 0, 3840 }
dispfmt: minScan, scan, maxScan:0, 0, 0
         data = { 2160, 0, 2160 }
dispfmt_CalculateCroppedArea:  X, Y, Width, Height = 0, 0, 3840, 2160
dispfmt:apply_disp: activeSource = 2, dispSrc = 2
datapath: Transition to IDLING on Vx1(ITE0)
dispfmt_ConfigManualWarp(): LensCorrection enabled = 0
dispfmt_ConfigManualWarp: Config warping failed with error code -16
WarpValidateResult->InLinesPixOK = 1
WarpValidateResult->HCtrlOK = 0
WarpValidateResult->VCtrlOK = 1
WarpValidateResult->WrpPointsOK = 1
WarpValidateResult->FailRow = 0
WarpValidateResult->FailCol = 1
 Actuator EEPROM size - 6 (where 0 = 0.125k,1 = 0.25k,2 = 0.5k,3 = 1k,4 = 2k,5 = 4k,6 = 8k)
 [Actuator Type]: 128   [AWC WG Auto-Offset]: 0
 Actuator Type: 128   Unipolar: 0
 XPR Param in EEPROM: MAtch Signature
XPR 4 Way Orientation number: 22
XPR: Act subframe order: 0 3 1 2
 XPR_4WAY_TIActGetActuatorData(): Read from EEPROM failed
 XPR_4WAY_TIActGetActuatorData(): Read from actuator failed!!!
datapathf: XPR_4WAY_Init Failed
SUCCESS: Product Configuration Valid, System Unlocked
Controller Info: Id = 0x01030059, Name = DLPC7540
DMD Info: DeviceId = 0x600D0096, FuseId = 0x00060008, FuseBitString = 00010000110110110, Name = DLP651NE_ECD_p65_1080p
illumination: Enabling SSI Driver...
sysmon: Transition to normal mode complete
sysmon: Completed _sysReset
sysmon: Init Complete
Startup Logo display time completed - 5037 milliseconds. Starting connector scan
------------------- SCANNING CONNECTOR : Vx1(ITE0) ----------------
Warning: No AFE1000/HW communcation found while attempting to place stand-by (However connector table seem to have a VGA entry)
IT6807 - iteState is ITE_POWERUP
datapath: Transition to SCANNING on Vx1(ITE0)
digcontrol: ConfigureForSearch complete
Event: Source Change Detected on channel
Event: DSM Locked on channel
digcontrol: FillSourceConfig - srcConfig:
        TotalArea.PixelsPerLine  - 2200,
        TotalArea.LinesPerFrame  - 1125,
        ActiveArea.FirstPixel    - 192,
        ActiveArea.FirstLine     - 41,
        ActiveArea.PixelsPerLine - 1920,
        ActiveArea.LinesPerFrame - 1080,
        PixelClockFreqInkHz      - 148500,
        inputFrameRate           - 59,
        srcColorType                        - RGB.
        srcConfig->IsInterlaced             - FALSE,
digcontrol: FillSourceConfig complete
Is3D = FALSE
dispfmt: DEI Disabled, Field Scaling Disabled
dispfmt: Input frame rate is 59Hz
dispfmt: input resolution: 1920 x 1080
         data = { 1920, 0, 1920 }
         data = { 1080, 0, 1080 }
dispfmt_CalculateCroppedArea:  X, Y, Width, Height = 0, 0, 1920, 1080
dispfmt:apply_disp: activeSource = 0, dispSrc = 0
dispfmt: DISP_SetDisplay failed (ret=-16)
         CroppedArea = { 0, 0, 1920, 1080 }
         DisplayArea = { 0, 0, 3840, 2160 }
datapath: dispfmt_ConfigureForSource failed 0
         CroppedArea = { 0, 0, 3840, 2160 }
Connector timeout is detected!, switching to next connector...
------------------- SCANNING CONNECTOR : Vx1(ITE1) ----------------
IT6807 - IT6807_PortSelect =  HDMI2
Source instability flagged by Front-end!, restarting Autlock...
------------------- SCANNING CONNECTOR : Vx1(DIRECT) ----------------
IT6807 - HDMI in POWER_DOWN
Event: DSM Lost Lock on channel
IT6807 - IT6807_PortSelect =  HDMI/MHL
        srcColorType                        - RGB.
Is3D = FALSE
        srcColorType                        - RGB.
Is3D = FALSE
  • Hello Paul,
    Thank you for the information. We are inquiring on our end and will get back to you early next week.
    Maxine
  • Hi Paul,
               Greetings!! As I look at yourUART logs, I see the DMD info and name is detected as DLP651NE_ECD_p65_1080p. Could you try flashing the "Flash_DLPC7540_DLP650NE_LED.img" and check the behavior.
  • Hi Venkata,  Good catch, but
    9
    source: SPLASH address:  0x10522d7c
    DMD Info: DeviceId = 0x600D0096, FuseId = 0x00070008, FuseBitString = 00010000111111111, Name = DLP650TE_ECD_p65_UHD
            srcColorType                        - RGB.
    Is3D = FALSE
            srcColorType                        - RGB.
    Is3D = FALSE
            srcColorType                        - RGB.
    Is3D = FALSE
            srcColorType                        - RGB.
    Is3D = FALSE
            srcColorType                        - RGB.
    Is3D = FALSE
    I fixed the firmware, but the problem remains.  Please let me know if you have any other ideas.
    Paul
  • Hi Paul,
           Thanks for the update! Could you try invalidating the settings in Administrative page - Eeprom Invalidate tab as below
       Also try resetting the warp map using a dummy 2*2 warp settings as below in Manual warping - Calibration Tab
  • Hi Venkata,  The Invalidate Settings didn't change anything, but the second step Calibration - Manual Warping fixed the problem!  Thank you very much, I would never have been able to fix this on my own.
    Paul
