Other Parts Discussed in Thread: DLPC350, , DLP4500
Greetings everyone,
I have refer to the video below (Youtube Video) when working with Lightcrafter.
Link: https://youtu.be/RxgmGkNsqvk
I need to check with you is there any special settings or configuration in hardware/software if the Lightcrafter does not operate with RGB LED Light Engine? I have tried using configuration same with end-user. We straight shoot the green laser to the DMD Display and put on the paper to display reflected light. I have attached the video for you to verify is the setup and expected pattern should be like that? Also, it will be great if you can show what pattern should appear. Does it same as in the video?
Video Link: https://drive.google.com/drive/folders/1JVyNqUth4s38xCvAKGoh843VhLpCpupx?usp=drive_link
Kindly assist me on this.
Thank you
