DLP4500: DLP4500: HDMI Computer Monitor Connection Issues
Part Number: DLP4500
I try to stream video/image pattern data to PRO4500 directly through mini HDMI connector from my PC.
I don't know if it's a hardware issue with DLP or a software issue, but the screen doesn't stream from my computer. Although I also changed the Mini HDMI/HDMI cable, it did not resolve.
What are some solutions I can do?
Thanks.
  • Hello User,
    Welcome back to the E2E forums and we hope to assist you with your questions.
    Can you check your GUI settings and see if you are in video mode at the top?
    Then please ensure under input configuration you are set to parallel RGB source.
    Also check the video signal information by pressing the "Get Video Info" and see if information is generated. You should see something similar to the following.
    Lastly I would also check the display settings on your computer. Can you see the pro4500 come up as a second screen? Double check the resolution is set to 1280x800.
    Alex Chan
