DLPDLCR230NPEVM:Repair inquiry
Part Number: DLPDLCR230NPEVM
Two of the products I purchased don't work.
One looks like the DMD is damaged, and one doesn't work.
Please check the problem.
  • Hello User,
    Could you please elaborate on what is the issue you are facing exactly. How did you conclude that DMD is damaged?
    How long has it been since you purchaser the EVMs/-
    Akhil
  • Output image noise is severe.
    If you want, I'll send you a picture by email.
    I bought it in September.
  • Could you please upload the projected image?
    regards,
    Vivek
  • Attached is the image and video.
    Please check.
  • Hello Jiyeon,
    Please check that the flex cable connection is secure on both of your EVMs. On the EVM that does not work, do any of the LEDs turn on at all?
    Maxine
    the flex cable connected properly. and the LEDs does not turn on.
    Thank you.
  • Hello Jiyeon,
    Due to the problems you are experiencing, please contact the seller you purchased the EVMs from to begin the RMA process. You may use this thread as proof of your issues.
    Maxine
    I bought it on the TI website.
    Please proceed with the RMA.
    If there is a separate application process, please explain it in detail.
    Thank you.
  • Hello Jiyeon,
    Please reach out to your local seller to begin the RMA process. Please refer to this page: https://www.ti.com/info/contact-us.html
    Lori
