Hello, senior TI engineer. I couldn't find the optical parameter drawing of 354171 as shown in the following picture in the information provided by TI. Could you please help me provide it? Thank you
Hello Chen,
Our expert is still looking into your question and will get back to you within the next few days. We apologize for the delay, we are still catching up from the holiday week.
Maximus
Hello Chen,
Thank you for your patient. It is a catalog part from Lightpath. You should be able to find information on their website. It also available on some of supplier site too.
regards,
Vivek
Hello, I have reviewed the drawings you provided and found an issue. I would like to consult with you: there is a parameter in 03571. pdf that is the design wavelength=633nm, as shown in the following figure; And in our DLPNIRNANO system, the optical path is in the range of 900-1700nm. Why is this small lens designed in this way to be 633nm, which is not in the range of 900-1700nm?
Hello Chen,
I will look into this and get back to you in couple of days.
regards,
Vivek
Hello Chen,
The part number should has "-C" added for wavelength.
Here is link to part on Thorlab
Thorlabs - 354171-C f = 6.2 mm, NA = 0.3, Unmounted Aspheric Lens, ARC: 1050 - 1700 nm
regards,
Vivek
