Other Parts Discussed in Thread: DLPC3433, DLPA3000
I ordered 3 DLPDLCR3010EVM-G2, but two out of the three seem to be defective. They do not project light when powered and switched on. 1 out of 3 worked normally.
Hello Ryoma,
Can you confirm the following:
Maximus
- Yes, the power supply is correct. The same power supply works for the other DLPDLCR3010EVM-G2 in the lab.
- Connections are good.
- GUI detect the 2 projectors when connected. However, no light output from the 2 projectors.
- The attached photos are OFF/ON of the 2 defective projectors. They show different LED patterns in their ON states, but both of them similarly do not output light.
Hello Ryoma,
Can you try re-flashing the EVMs with the latest firmware found from TI DLP Pico Firmware Selector Tool?
Maximus
Hi Ryoma,
The DLP3010EVM-G2 uses a DLPC3433. You should have the selections below in the firmware selector tool.
Maximus
I got this error when I tried to upload the firmware image:
Error: Firmware selected is meat for a different EVM.
Hi Ryoma,
This is interesting. Could you try flashing using our LC GUI? It has more relaxed flash restrictions and can sometimes work better. Here is the link to download (link).
Maximus
I could finish uploading the firmware using the LC GUI. However, the 2 projectors still do not output light. I also noticed that the GUI indicates at the bottom left that the EVM is "Powered Off" even when I switch the projectors ON.
Hello Ryoma,
We recommend proceeding with an RMA. If you ordered through TI.com please see the following link, otherwise please contact your distributor.
Maximus
Should I reference this forum thread somewhere on the return request? We ordered through TI.com, but this order was made by a procurement team at my institution. They used a different TI account (adrian.orozco[at]ufl.edu) for this purchase.
Is it ok to submit the return request using my own TI account (rhattori@ufl.edu) as long as I reference the correct order number?
Hi Ryoma,
You may reference this thread in your ticket. I am not aware of the TI customer return policies, but they should be able to answer your questions regarding return once you reach out to them. Sorry for the inconvenience.
Maximus
Ok. Another question. I need to fill out "DTC/LTC" on the return form, but I cannot find DTC/LTC on my DLP3010EVM-G2. Do you know where I can find the numbers on DLP3010EVM-G2?
The DTC/LTC is applicable to the semiconductor chips we sell, not EVMs. Please put "not applicable".
Maximus
